N@Z
Mint META headphone amp
As requested by Ckng,
Marantz CD-80 (fixed analog output) -> DNM Reson+Eichmann Bullet RCA plugs -> KurtW META -> AKG K501
Had to relisten to Mint prior to the 'normal' META. Incidently the specs & original META vs PCII comparison were posted here. The following are just my impressions in point form & put down as & when I listen to them.
Tangent Mint META
Rage Against the Machine - RAGE : Tight punchy bass with very good extension. Very forward upfront sound. Maybe a tad bright & harsh at times.
Lisa Ono - Luesta Bossa Mia : Pleasant airy sound. The bass is less pronounced here emphasis on clarity.
KurtW META
Lisa Ono - Luesta Bossa Mia : Top end is more controlled. Bigger soundstage. More detail & clarity in the music, like faint nuances & separation of instruments. Bass is pretty much the same, except on 'O Sole Mio where there's this drum which sounded like it had a little more weight.
Rage Against the Machine - RAGE : The weightier sound is apparent here. So is the bigger soundstage. Guitars sound less conjested.
I think the I/C's helped with the punchy bass which I heard even with the Mint META (on Rock). The Van Den Hul sounds brighter. The K501 worked quite well on both META amps. FWIW, at one point I forgot about writing this & was lost in the music! This happened with both amps wink.gif lean bass or otherwise!
I think only the HD600 with Equinox cables will ever convince me to let go of these headphones. So I'm 1/2 way there so... Headphonecrazy, look into my eyes... you will GIVE me your cables... LOL! Enough OTing!
As usual, the PORN
Now where is the op-amp?!
You win the $1 throphy! Hehe... my next question is, why?!
why? hmm..thats a good one. I've no idea why its on the underside blush.gif to make it neater?
Probably a SMT one. The META docs say there are pads for SMT Op Amps like the AD8620. smile.gif
N@Z: Thanks for the review!
Regards
CK
ckng: The op-amp is an AD8620. I still am not sure why it is down there, unless it is harder to solder on the top but what would I know! blush.gif
Jtfoo: That actually is the 'blend pot' it control's the amount of crossfeed operated by the toggle switch next to the volume pot.
Well, the AD8620 is a SMT IC, meant for soldering directly onto a PCB. This is unlike the other DIP-format ICs (like the 2 TL2001CN buffers seen in the pic) which you can fit from the top directly or via a socket. smile.gif
Regards
CK
Or maybe that is why you have the brown dog adaptor then IIRC the OpAmp will have no space to go underneath. Hence the Adaptor not only free the space but reconfigure the opamp to the PCB due to the rightside up from right side down placement (sorry I can't describe it technically).
Please correct me if I'm wrong, thanks!
Edited by matbon0013
The Brown dog adaptor, that is not the same as the ones used by the Buffers?
