Kippei
Tubes amp
Okay ... i measure the wrong point... plate volt lowest i can get is 47v. Reversed my volume pot. Not sure whether my trimmer is soldered correctly.. It is just connect the center pin and the 2 either pins.
if u reduce the trimpot value, voltage at the plate should drop
if u increase the trimpot resistance, the plate voltage should increase
did u put fixed resistor besides trimpot?
did u wire the trimpot correctly? out of the 3 legs, how did u wire them?
that's how I put the jfets for my 2 unit, too
but there's another connection, have u connected it? the top jfet S leg to the lower jfet's D leg
yep for the jfets even for the D to D too.
Eg The trimmer i connect the center pin to the left pin and connect the cap to it and out it goes to the tube socket and gnd. The left over pin i connect it to 560 and out it goes to the same tube socket pin.
huh?
why tube connect direct to ground also? then your trimpot is practically useless. that's why your voltage not changing when u turn the trimpot
and one more thing, D is NOT connected to D
D at the top, goes to 60V line
D of the lower jfet connect to S of the top jfet
fixed... i place the jfets in the wrong orientation... the gate got connected instead of the source... now its working cept for the buzzing... haven put output resistor yet...
I means it doesnt sound as good as what i expected....
The buzzing tml den settle. Been working on it for 15 hours straight...
for buzz, try redo the 3 wires from the trafo
either tuck it hard or something when the unit is on, but becareful, dun get electrocuted laugh.gif
oh yea, have u got any fluorescent lamp that's nearby? turn it off and listen again.
I packed the hot ends with 2 layer of heatshrink.... betta safe den sorrie....
But i got a few time buzzless and quiet but dunno what i touch.
try and try again to redo what u've just done
which side u put heatshrink?
o yea, the DC blocker at trafo's primary winding, it will make the trafo really runs a lot cooler
