Kippei 0 Report post Posted January 6, 2006 yeah i found it much better than sticking onto some board with holes. Which layout are we using Share this post Link to post Share on other sites
squalle 0 Report post Posted January 6, 2006 this one: http://headwize.com/ubb/showpost.php?fnum=...=46715&fpage=16 the pattern already drawn up Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 polyproplene... did u find any in koba???? I think i saw before, but cant seem to find it.... Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 The board may not fit some of ours parts. Like the trimmer, it may not fit yours.... Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 I like single pads better as it will be more flexible in making the layout as you like it the 2 strips I have are only at the two sides, then I utilized one of them as my ground so you can start already ? or wanna come here and do? I need to make another one for a friend I just notice that the strip trace can be cut out for more flexibility and neater Share this post Link to post Share on other sites
kross 0 Report post Posted January 6, 2006 (edited) the places sells a lot of things, big place. take your time to shop for other diy things if you have a time. might have a good kill there. (your wallet too... ) ya, there are many wooden boxes there, at least so when i last went there. all at a corner. ya, the wood is thick, for needed strength i think. i have tot of a way to make the wood thinner...dunno can work or not. tat is to drill 3mm hole through..then use about 6mm - 8mm drill bit to drill halfway. might create a concave that might let the headphones plug go inner a bit, hopefully. will try tmr. my current box is about 2.5inch by about 4 inch i think Edited January 6, 2006 by kross Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 Why dont you try the reverse drilling ... with the jack flush with the surface so no ugly holes. Share this post Link to post Share on other sites
kross 0 Report post Posted January 6, 2006 Why dont you try the reverse drilling ... with the jack flush with the surface so no ugly holes. hmm...good suggestion. will find some scrap wood to try both tomorrow. Share this post Link to post Share on other sites
squalle 0 Report post Posted January 6, 2006 kross: u forget 1 thing the bigger diameter drill, you cant make it flat ended (counterbore we call it) if u use the drill bit that is to make hole but the milling bit is flat, so that's why I asked for milling machine kippei: I dont like the board with strips if you're not careful when u assemble everything then forget to cut some strips, you might kill some parts and cutting the stupid strip aint fun either then for PCB, maybe later on I draw up something. see if I can do that never draw up a PCB before Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 (edited) Cant wait to see pcb... As for the tube mount on the boxtop. You can also try flushing it at the socket top. **If I am not wrong the serperated pcb is to keep the power unit and the sound unit apart ***You got all the material to etch boards??? If not Bell from SLT got sell a lot of this stuff. Nice place. Edited January 6, 2006 by Kippei Share this post Link to post Share on other sites
squalle 0 Report post Posted January 6, 2006 I dont have but I dont think it's going to be expensive rite? you really wanna wait till I got around to make the PCB? Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 (edited) no idea... but the stuff should cost less den $30 cept the laser printer with the ferric recycleale. it look quite simple from here... Maybe the next payday embark on a trip to PCB building. I also bought the parts for dablok just now. The diode for 1kv look so strange... ** Its a fast recovery diode... what it means?? Edited January 6, 2006 by Kippei Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 6, 2006 (edited) Now i am trying to use this program call VCAD and Tinycad to auto layout the stripboard **Failure... i couldnt draw the darm thing into the cad Edited January 6, 2006 by Kippei Share this post Link to post Share on other sites
squalle 0 Report post Posted January 6, 2006 have u seen this layout? http://headwize.com/ubb/showpost.php?fnum=...=47069&fpage=20 Share this post Link to post Share on other sites
1bit 0 Report post Posted January 6, 2006 ** Its a fast recovery diode... what it means?? iirc it means that the diode can recover quickly from blocking (due to reverse bias) to conducting so the transition time between blocking/conducting when the bias is changed is shorter hey guys, a bit lazy here. since you've been discussing about the tube amp quite long already, i might as well ask: actually what's so different with the 3 hybrid amp design between SOHA, YAHA, and MHHA? i'm getting the sijosae's MHHA kit from neutralzz next week so i'll try building MHHA first anybody built the multi-hybrid amp already? i know kippei and squalle is building the SOHA, how about kross and huangyong? Share this post Link to post Share on other sites
