jtfoo 0 Report post Posted November 4, 2003 This is the discrete rail spliter i mentioned, 100mA max output vs TLE2426's 47mA. http://headwize2.powerpill.org/ubb/showpag...d=4381&fdays=20 Thanks for this link.. At least learn something today.. Share this post Link to post Share on other sites
kenshinz 0 Report post Posted November 4, 2003 kenshinz, i think you should use a better IC socket, this 1 is hard to work with. U refering to me or tropicalrips ?? My amp is not even done yet sigh.... hopefully wun have any problems. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 4, 2003 what would the transistor values be for the rail spilter? i think its true u can learn a lot from the problems of the Cmoy i now hav the circuit in my head, my second board was done without looking at the drawings but i still can't figure out the problem... i know the voltage is driffting to 1 side, but this only happens when the op-amp is in place, when i take it out, the voltage on both sides is the same +- > 0.3v so i think i need another op-amp to confirm anyone hav extra op-amp lying around? Share this post Link to post Share on other sites
huangyong 0 Report post Posted November 5, 2003 get a cheap opamp to try first.if spoil wont loose so much $$. Share this post Link to post Share on other sites
kenshinz 0 Report post Posted November 5, 2003 Here's a quick update on my Cmoy, have just finished soldering all parts together, except for the wires connecting the batteries to the board (My soldering iron decides to give up the ghost at that point ) My soldering sucks this time round, and the board is not as neat as my 1st board. Tried to use scotch tape to tape the connections together to test the amp, and it works . Except now got the same problem as tropicalrips regarding the hissing sound Another thing problem is that when i tried to connect the 2 batteries together in series without grounding them, they work fine, but when I tried to ground the centre of the 2 batteries ( (-) from the 1st batt and (+) from the 2nd batt) to the board's ground, 1 side becomes muted, and I keep hearing a click click sound coming from it when there's no music playing. Any ideas why this happens ?? BTW, I'm not using the R2/R3 voltage dividing resistors to the board following Jason's advice, will adding them in help ? Thanks !! Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted November 5, 2003 Did you connect your input output correctly? Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 5, 2003 kenshinz, i think we hav check all our resistor value one more time to confirm everything, we may all be mislead by the list on Tangent's site anyone can list the exect values for a basic CMOY without any optional parts & tweaks? jason? is the original design using all 4.7k (including the voltage divider) except R4 (10k) which is on the output side after the cap. we should hav made up a list of the values from the begining, i was very confused by the list on Tangent's site, and all the other writings and drawings on the net, had to keep going back & forth just to figure out which resistor goes where Share this post Link to post Share on other sites
kenshinz 0 Report post Posted November 5, 2003 I think the hissing sound is due to improper soldering...was playing around with the voltage connections.. at certain angle, the hissing sound was reduced abit. Therefore I presumed that the soldering was not done properly somewhere on the board. BTW, Jason, what happend when I don't ground the voltage ? Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted November 6, 2003 You would hear mono sound on both phone. Kenshinz, I think your amp is picking up stray noise in the sourrounding. Try adding 10nF ceramic at the supply and see does it help. At tangent's site, he recommend the best way to fix the unbalance rail problem by adding a TLE2426 and another buffer. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 6, 2003 (edited) i hav ordered another op-amp from federal today, collecting it tomorrow, then i'll know if the fault is in the op-amp or somthing else can get the rail-spilter off the shelf in SLT? wish me luck Edited November 6, 2003 by tropicalrips Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 10, 2003 Finally done, my first Cmoy Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 10, 2003 all the problems were caused by the op-amp, everthing work fine when i put in a new op-amp Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 10, 2003 did not hav to use the rail-spilter, i think i will try it when i change a new board, need to redo the wiring Share this post Link to post Share on other sites
N@Z 0 Report post Posted November 10, 2003 Nice. Would it be neater too if the headphone out socket is built onto the enclosure. Or is there not enough room for that? I'm beginning to like the Portapros looking at yours in the photo! Share this post Link to post Share on other sites
jtfoo 0 Report post Posted November 11, 2003 Nice job.. The knob looks a little big. But still better then my knobless cmoy.. Share this post Link to post Share on other sites
