tropicalrips 0 Report post Posted November 16, 2003 size difference of the caps Share this post Link to post Share on other sites
jtfoo 0 Report post Posted November 16, 2003 Your R5 is 43K or just 43R ? 43K seems too big. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 16, 2003 (edited) its 43ohms sorry i hav tried 43 & 47ohms, don't seem to hav any effect on the porta-pro slight different with those low impedence phones, went with 43 cause i hav a 16ohm Koss plug Edited November 16, 2003 by tropicalrips Share this post Link to post Share on other sites
N@Z 0 Report post Posted November 16, 2003 Cmoy can be bias into class A but i didn't hear any difference. just connect a resistor between the V- and the out put will do. check this out in tangent's web page. and bout volume pot. i think alps blue is overkill. Omeg is sucks, i tried it in three amps all failedl. dun know why?? the resistance will increase a lot for first turn then the rrest almost the same resistance. soi think is it possible to use a lousy pot and a JFET circuit to control volume by biasing the jfet with different voltage and change their impedance.... is it linear??? possible??? If your source & headphones are up to par you will hear a difference with Class A. I noticed it while swapping from Class AB to Class A on the PCII. Sound became more open & better defined. COrrect me if I'm wrong but the argument for Alps volume pot is not on quality alone but less channel imbalance at low volume. Share this post Link to post Share on other sites
Q00 0 Report post Posted November 16, 2003 but its a low ohm value version of the alps blue right? Share this post Link to post Share on other sites
jtfoo 0 Report post Posted November 17, 2003 I think HY is referring to the brand OMEG that is lousy, not the blue alps. Blue alps is imo decent for most audio diy, but agree with HY, for the price it's an overkill for a cmoy.. save the blue alps for bigger project like the meta42. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 17, 2003 those big Elna caps only $0.20 each. anyone know why they are so cheap? i bought the one in the middle for $0.80 each they are the same spec only different size Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted November 18, 2003 You just said it, size. Smaller with the same spec more X. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 18, 2003 i will try laying the caps on their side so they can fit into the Cmoy case, will this cause problems? there is still a lot of room left on the basic cmoy board layout, going to try and make use of them Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted November 18, 2003 no prob man... Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 18, 2003 (edited) hav some extra parts so thought i try this micro Cmoy with gain of 6, it does hav enough space for the R5, tried it with my HD-570 no problem Edited November 18, 2003 by tropicalrips Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 18, 2003 one more pic of the back, no jumper wires now to find a case for it Share this post Link to post Share on other sites
N@Z 0 Report post Posted November 18, 2003 Ooh! Nice! Before long you'll probably build something like the SuperMini size! How does the sound compare with your original CMOY? RS (or equivalent) has a nice little black (4x) AA battery case which should be able to fit it in including a single 9v battery. If you don't need it so small, use a Mint tin & squeeze in 2x 9V batteries Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 19, 2003 it sounds the same i think, the mini may hav a little more bass impact then the micro because of the bigger caps but i think its just a psyhological effect Share this post Link to post Share on other sites
kenshinz 0 Report post Posted November 19, 2003 Nice work dude, haha before long, think you can have a Cmoy production line liao Share this post Link to post Share on other sites
