N@Z
Need help to build
It's a "glorified CMOY" design, the only addition being the unity gain buffer at the output stage.
10k resistor in blue is your potentiometer. You need a good one here, else you may end up with unbalanced left and right channels. Alps has good tolerance, difference is less than 0.2dB.
The 1uF capacitor acts as a filter for your input ac signal.
IC1a is the the gain amp, i.e. it amplfies your input voltage by a scale factor, depending on the resistor values that you have chosen. The resistors are the 1K and 10K in green. For this diagram, the gain is 11, cause it's a non-inverting amp, so it's (10K divide by 1K) plus 1. You got to practise caution when choosing the gain for IC1a because too much and you will cause the amp to clip in no time but too little and you will need to crank up the volume control by quite a fair bit.
IC2a is the unity gain amp or buffer. I couldn't recall how much current the opa2132 can provide, but it's definitely lesser than the EL2002/2001 buffers. Each buffer is itself a unity gain buffer with a max output current of 120mA. An advantage of the buffer is that it protects IC1a's output from being "loaded" by your cans impedance.
Okay, that's all I can say for now. BTW, the buffers ain't cheap, probably 2.5 times the price of the OPA2132 and if you add 4 per channel, that means you need 8 of them. biggrin.gif Maybe it's more cost effective to use the OPA2132. wink.gif
laugh.gif Thanks for the info Northern Oak. I read through it very carefully. I will use some of what you said to make my parts selections. wink.gif
Passive Crossfeed -> Channel Mixing -> It fills the voids in the sound stage spanning from the left ear to the right ear so that it will sound more like a speaker setup.
Based on my past experience, it may be better to push the gain higher, perhaps somewhere between 15~18 but maybe not to x30. If you're bent on getting x30, it may be wiser to up the rail voltage from +/- 4.5V to +/- 9V instead.
So I will need 2 9V batteries? unsure.gif I suppose I can accomadate that. Im not gonna really be using it for portable anyway.
hmm...maybe. Cause I'm not really building a portable one but one for my PC, will be tapping the 12V DC from the PSU so can get +-6V...
I'm not sure about opamps, but can I just use any level of supply voltage? There should be a minimum and max? sorry me a newbie....
May I know what PSU are you referring to?
Yes, there's a minimum and a maximum supply voltage :
+/-2.5V to +/-18V.
jasonhanjk:
hmmm, what are you referring to?
The wires from a computer PSU.
My new one has heaps of extra wires. wub.gif pretty thing it is
Yellow wire is the 12v connector.
jason : black wire dont matter, all black wires are grounds.
Good luck on that then... Computer PSU's are all switching units and are very noisy.
My new psu is quite quiet. laugh.gif dual fan unit. I don't want to make a PSU powered amp though. Maybe later on. haha.gif
Mechanically quiet but what about electrically? Point to ponder.
Forgotten to add that your K501 would sound better with the CMOY if you used more than 1 buffer. 3 would be okay, I guess.
