tropicalrips 0 Report post Posted August 17, 2004 it looks good will it be difficult to get the pot mounting on the case if the pot is already soldered to the PCB? we might hav to try a few times to get the mountings on the case just right, need to note down the measurements for the holes to be drilled. i would like to try my starget & cerafine caps on this amp Share this post Link to post Share on other sites
Q00 0 Report post Posted August 17, 2004 Agreed! It does look good. Soo close now.. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted August 18, 2004 The panel have to drill according to the pot after it is being solder to the PCB. All should be the same height as they are snap in type. Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 18, 2004 FYI, I just bought small ALPS (around 1x1 cm body size) from Farnell, they cost less than SGD 3.- per piece. Forgot the order code. I will search the invoice if you interested. Snap in type to PCB, green color. Share this post Link to post Share on other sites
heady 0 Report post Posted August 19, 2004 bpribadi, is it 50k with centre detent? The quality is not bad, I tried it. Only problem is the bushing is too long and so it the stem (or whatever it's called). Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 19, 2004 Ok, I got the Farnell order number, it is : 919615 (Dual 10k log) 919627 (Dual 20k log) 919639 (Dual 50k log) 919640 (Dual 100k log) For your convenience .... The price list is SGD 7.08, but they charged me less than SGD 3.- per pot. You know sometime Farnell give discount for certain items without telling us Well I think it is odd to have centre detent for volume, so I prefer the one without. You are right about the bush, they a bit too long, so sometime we need to cut it (I use file to cut it). Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 19, 2004 The price is confirm SGD 2.13 (w/ GST) for the 919639 (Dual 50k log). No stock for other values. I don't know how long Farnell will sell it with this price, so hurry !!! Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted August 19, 2004 The problem with Farnell is when they find out they under-charge, they'll be back to ask for payment. This happen when I got something cheap from RS. Maybe they'll never find out... The one you recommend is RK9 series from Alps. Link here: http://www3.alps.co.jp/pdf/2004pdf/pdf_e/P...tal/9_metal.pdf RK9 characteristic: 1. 15,000 cycles life 2. 11.35mm in height 3. Takes 12.4mm deeper into the PCB space RK12 characteristic: 1. 10,000 cycles life 2. 15.5mm in height 3. Takes 8.5mm deeper into the PCB space 4. Enhanced structural design has improved cross talk and gang error characteristics. The previous RK14 is too tall by 1mm and the RK9 takes critical PCB area away. Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 20, 2004 This time is not under-charge. Yesterday mukegile and me went to Farnell to check the price one more time, and he bought a few pieces as well. The price is correct, confirmed by the lady at the counter. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted August 21, 2004 What are you guys waiting for?!!! Go for this alps pot! Worth it. Who going over to Farnell buy can buy for me too... Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 21, 2004 Let me know how many you want, I have customer near Farnell and I go there quite often Share this post Link to post Share on other sites
Goondu 0 Report post Posted August 29, 2004 How's it coming? Looking good Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted September 2, 2004 Sorry guys, need to delay to a next possible date. The launch date would be December 25, delay is due to choosing the wrong pot. Final design would be using RK9. Will post some images over the weekend. Share this post Link to post Share on other sites
maddog 0 Report post Posted September 10, 2004 way to go I'm looking forward to it!! Share this post Link to post Share on other sites
