huangyong 0 Report post Posted July 14, 2006 board is going to ship out soon.. Edwin pls give ur address to digi01. thanks. Share this post Link to post Share on other sites
digi01 0 Report post Posted July 15, 2006 货物已经发出.下周末前抵达. Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 15, 2006 货物已经发出.下周末前抵达. Share this post Link to post Share on other sites
Kippei 0 Report post Posted July 16, 2006 Been waiting long for this.... Share this post Link to post Share on other sites
digi01 0 Report post Posted July 16, 2006 Been waiting long for this.... sorry for delay Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 16, 2006 Been waiting long for this.... sorry for delay No worries, bro! Its always good for the delay when we know we are getting more improved boards. Share this post Link to post Share on other sites
huangyong 0 Report post Posted July 16, 2006 hooray!!!!.. SOHA on the way.. Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 17, 2006 (edited) Ok, here will be the final layout ver. 3 of our Mr. Digi's SOHA. Changes made: 1.CCS layout modified basis on reviewer suggestions. 2.rebuild Q1-Q4 footprint for newbie friendly. 3.move output resistors out from under the opamp. 4.the tube-illuminating LED pads. 5.enlarge the footprint for the filament diodes. 6.add pads to C2, C14 to accept 10mm lead pitch. 7.add pads to C7, C8, C11 to accept 2mm lead pitch. Edited July 17, 2006 by Qsilver Share this post Link to post Share on other sites
heady 0 Report post Posted July 17, 2006 Will there be any kind person willing to write up a BOM? (bill of materials - list of components to buy for the amp). Help this old man.... Thanks. Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 17, 2006 (edited) Will there be any kind person willing to write up a BOM? (bill of materials - list of components to buy for the amp). Help this old man.... Thanks. Well I guess the standard value parts is the same. Only diff is if use JFET, MOSFET or plate? I am not sure myself too. Guess the best person to come out with it would be Digi himself? Edited July 17, 2006 by Qsilver Share this post Link to post Share on other sites
thedoctor 0 Report post Posted July 17, 2006 the JFET are somewhat too fragile to be used. at least the J113 are. 2SK30A are not pin compatible with the board though those are a lot sturdier. and thus i would suggest the LND150 MOSFET or the 1N5297 CRD. Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 17, 2006 the JFET are somewhat too fragile to be used. at least the J113 are. 2SK30A are not pin compatible with the board though those are a lot sturdier. and thus i would suggest the LND150 MOSFET or the 1N5297 CRD. Thanks for the pointers As for your preference, which would you use? LND150 or 1N5297 CRD? Share this post Link to post Share on other sites
thedoctor 0 Report post Posted July 17, 2006 Thanks for the pointers As for your preference, which would you use? LND150 or 1N5297 CRD? which one is easier to find, and which is cheaper. the LND150 are the toughest of the bunch, but might be hard to source for. i can't find them in Malaysia (even Farnell and RS don't stock them). you guys up south might have better luck. the CRD (1N5297) is the easiest to work with, and should suffice the voltage used in the amp. though CRDs tend to be costly. but taken that CRDs are easily replaceable with other compatible parts if should the 1N5297 is nowhere to be found, then i would opt for them. and one should most probably have easier time working with CRD than MOSFET (LND150). CRD is reverse polarity protected, and you won't burn them by plugging them in the wrong direction (well theoritically anyway). as for MOSFETs, most should survive, but i've burned (exploded really) one MOSFET by plugging it the wrong way. Share this post Link to post Share on other sites
heady 0 Report post Posted July 18, 2006 Thanks guys. Hmmm.... I am beginning to think I am getting into deeper waters than I can handle. Help........ Share this post Link to post Share on other sites
Qsilver 0 Report post Posted July 18, 2006 (edited) Just wanna add an important note for those who intend to use LND150* Rotate 180 degrees to install 1ND150 as DGS has been reversed to DSG. Please ignore this for those who already knew it. Edited July 18, 2006 by Qsilver Share this post Link to post Share on other sites
