Morgan Wu
DIY guide for LOD
Thanks for the guide Morgan ! :))
Some iPod LODs I made with Wireworld Oasis 5 and Canare L-2E5
nicely done.. now you are itching me to trying making a LOD to RCAs xD
is it? wow.
Man should have seen this earlier cos i order together with some others some blackgates from on9 with some friends, if u are really keen u can get from me some. i still dont know the price yet should be around 5sgd i think. i brought 30 of them.
O yea, just to clear up some of the confusions around here, There are 2 different types of caps basically :
Electrolyic caps :
This caps are basically the smaller caps that are used for imod, for example blackgates 4.7uF 6.3V. This caps are the caps that are mostly added in LODs, or inside of amps.
Usually they cost from around 50cents to 6bucks for the smaller ones.
Film caps :
This are the caps that produces major differences to the sound that is coming and they are bascially bigger then the normal ones, and depending on the brand this babies might cost up to hundreds per piece! u need 4 in total, around 500+? depends on the brand.
some examples of this caps are Valgrinds~ ALO V-Caps
Edited by JoshuaTan
Sorry for bumping this thread up but I want to ask if anyone here know the pin out for the Pailiccs 3.5mm plug(which is left, right and ground)? They look very different from Neutriks and I do not have a multimeter to check them out. Thanks.
just wondering, can BG 47uf 16v be used in lods for imod? got lobang to get it at about SIN30 each.. dunno is it considered cheap or not?? =X
sorry to bump an old post.. decided to start reading threads since i'm still bored at work...
but.. BG 16v 47uf so expensive meh?!?!?!
i have 3-4 pieces left... dont remember them being that pricey last time.. maybe four or five dollars thats all
another dock
Hello
I've been searching for the required equipments to make a LOD cable
but i couldn't get a single piece of info...
could you please tell me the things i need to buy to make one...?
and if possible, could you send the list to this address.....? ppoiu1945@naver.com
thanks for reading my "quote"..
Isn't the parts list quite obvious in the first post?
Thank you i re-read the whole post and listed the items needed
but... could you tell me the brand of the wires used?
u see, im currently living in korea and couldn't find the appropriate wires to use
specifically, i couldnt find the wires "thin" enough...
:cry:
and the amp in the photo is CHA47 that i have made recently
i would love to use my handmade cable to connect to it..
so... could you please let me know (at least) the names of the cables...?
